Старый 18.05.2015, 12:11   #1
bojensen: There was an error while trying to deserialize parameter http://tempuri.org/:queryBuilderArgs.
Источник: http://blogs.bojensen.eu/2015/05/18/...rybuilderargs/
  There was an error while trying to deserialize parameter http://tempuri.org/:queryBuilderArgs. The InnerException message was 'Element 'http://tempuri.org/:queryBuilderArgs' contains data from a type that maps to the name 'http://schemas.datacontract.org/2004/07/XppClasses:SRSQueryBuilderArgs'........................................Some times we get the above error while running reports in Axapta 2012. To resolve this issue we need to delete usage data in the AOSserver. Solution :…
Read more →
bojensen: How to Default to ALL in an SSRS Multi-select Parameter » The Data Queen Blog bot DAX Blogs 0 14.11.2014 20:11
emeadaxsupport: Manufacturing Execution in AX 2012: Issue with the "Lock employee"-parameter Blog bot DAX Blogs 0 19.09.2013 18:11
emeadaxsupport: "Parameter is missing a value" error running a customized report in Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 21.11.2012 00:12
mscrmblog: This report requires a default or user-defined value for the report parameter ‘Parameter’. To run or subsribe to this report, you must provide a parameter value Blog bot Dynamics CRM: Blogs 1 09.12.2010 09:51
Developer notes: Null value for ADO command parameter Blog bot DAX Blogs 0 03.05.2008 08:16
Часовой пояс GMT +3, время: 08:29.
