Старый 20.08.2007, 15:37   #1
radya is offline
radya
Восемь датасоурсов на форме
Всем доброго дня !!
(Ax3.0 SP4 Sql2005 трехзвенка)
На форме 8 (восемь) датасурсов, вот код на init формы:
Код:
Query query1,query2;
QueryRun queryRun;
QueryBuildDataSource qbds1,qbds2,qbds3,qbds4,qbds5,qbds6,qbds7,qbds8;
QueryBuildRange qbr1,qbr2,qbr3,qbr4,qbr5,qbr6;
query1 = PurchLineDesign_Q;
qbds1 = query1.dataSourceTable(tablenum(PurchLine));
qbds2 = query1.dataSourceTable(tablenum(InventDim));
qbds3 = query1.dataSourceTable(tablenum(PurchClaimPurchLine));
qbds4 = query1.dataSourceTable(tablenum(PurchClaimTable));
qbds5 = query1.dataSourceTable(tablenum(SalesLine));
qbds6 = query1.dataSourceTable(tablenum(SalesTable));
qbds7 = query1.dataSourceTable(tablenum(InventReferenceTrans));
qbds8 = query1.dataSourceTable(tablenum(InventReference));
qbds1.clearLinks();
qbds2.clearLinks();
qbds3.clearLinks();
qbds4.clearLinks();
qbds5.clearLinks();
qbds6.clearLinks();
qbds2.addLink(fieldnum(PurchLine,InventDimId),fieldnum(InventDim,InventDimId));
qbds2.joinMode(JoinMode::InnerJoin);
qbds2.fetchMode(0);
qbds3.addLink(fieldnum(PurchLine,RecId),fieldnum(PurchClaimPurchLine,purchLineRecId));
qbds3.joinMode(JoinMode::InnerJoin);
qbds3.fetchMode(0);
qbds4.addLink(fieldnum(PurchClaimPurchLine,PurchClimeRecId),fieldnum(PurchClaimTable,RecId));
qbds4.joinMode(JoinMode::InnerJoin);
qbds4.fetchMode(0);
qbds5.addLink(fieldnum(PurchClaimTable,SalesRecId),fieldnum(salesLine,RecId));
qbds5.joinMode(JoinMode::InnerJoin);
qbds5.fetchMode(0);
qbds6.addLink(fieldnum(SalesLine,SalesId),fieldnum(SalesTable,SalesId));
qbds6.joinMode(JoinMode::InnerJoin);
qbds6.fetchMode(0);
qbds7.addLink(fieldnum(PurchLine,RecId),fieldnum(InventReferenceTrans,purchLineRecId));
qbds7.joinMode(JoinMode::InnerJoin);
qbds7.fetchMode(0);
qbds8.addLink(fieldnum(InventReferenceTrans,InventReferenceId),fieldnum(InventReference,InventReferenceId));
qbds8.joinMode(JoinMode::InnerJoin);
qbds8.fetchMode(0);
qbr2 = Global::findOrCreateRange_W(qbds2,fieldnum(InventDim,InventProjectId),'условие');
PurchLineDesign_DS.executeQuery();
Кроме того на форме есть грид , со свойством DataSource = PurchLine и колонками из 8 этих самых датасурсов. Не отображается информация в колонке грида InventDim.InventLocationId , и все что связано с InventDim и InventReferenceTrans. Фильтр InventDim.InventProjectId тоже не срабатыает. Вот текст query1
Код:
SELECT FIRSTFAST * FROM PurchLine
JOIN FIRSTFAST * FROM PurchClaimPurchLine
    WHERE PurchLine.RecId = PurchClaimPurchLine.purchLineRecId
JOIN FIRSTFAST * FROM PurchClaimTable
    WHERE PurchClaimPurchLine.purchClimeRecId = PurchClaimTable.RecId
JOIN FIRSTFAST * FROM SalesLine
    WHERE PurchClaimTable.SalesRecId = SalesLine.RecId
JOIN FIRSTFAST * FROM SalesTable
    WHERE SalesLine.SalesId = SalesTable.SalesId
JOIN FIRSTFAST * FROM InventDim USING INDEX DimIdIdx
    WHERE PurchLine.InventDimId = InventDim.inventDimId
OUTER JOIN FIRSTFAST * FROM inventReferenceTrans
    WHERE PurchLine.RecId = inventReferenceTrans.purchLineRecId
    WHERE inventReferenceTrans.inventReferenceId = inventReference.inventReferenceId
Вроде бы все корректно выглядит. Но почему не отображается информация из InventDim ??? Я уже сломал голову.
Пробовал добавлять фиктивные ссылки по DataAreaId на все подчененные датасурсы - не помогает. В чем может быть причина ?
Спасибо
ax3.0
Использование семейства InventDimCtrl_Frm_* - 2 DS InventDim на одной форме Pavlo AKA Panok DAX: База знаний и проекты 5 22.12.2008 17:15
Как не выводить заголовки в форме, если нет строк? DreamCreator DAX: Программирование 9 29.05.2008 15:10
Название полей в форме запроса PavelSR DAX: Программирование 4 11.07.2007 17:19
Добавление источника к запросу на форме Lucky13 DAX: Программирование 1 21.05.2007 17:12
BugFix: В форме складских журналов нельзя перемещаться с помощью клавиш курсора Maxim Gorbunov DAX: Программирование 5 21.01.2005 01:20
Часовой пояс GMT +3, время: 02:24.
