Старый 29.10.2007, 10:50   #1
Inside Dynamics AX 4.0: Configuration and Security
Источник: http://feeds.feedburner.com/~r/Insid...-security.html
Microsoft Dynamics AX 4.0 is targeted toward businesses whose size, location, language, and line of business vary widely. Security system configuration, personalization, and presentation layout become significant features when you are implementing and using the system.
This chapter describes how the Dynamics AX 4.0 application runtime implements configuration and security and how these concepts determine the interface that the user sees. IntelliMorph is the unique technology for designing and developing the application forms, reports, menus, and menu items. The IntelliMorph technology encompasses essential framework elements that influence the final output within licensing, configuration, and security. The licensing and configuration frameworks give you the option to license application modules, thus providing access to various application areas. You may also enable and disable functionality independently of the licensing.
This chapter discusses security in the context of the application runtime, and it also offers details about important security aspects to consider when developing the application. The last section in this chapter covers the concept of data access security, which makes it possible to differentiate business data access across user profiles. This feature enables query construction to extend the table permission options available in Microsoft SQL Server. The feature that differentiates business data access is called the record level security framework.http://insidedynamicsax.blogspot.com/
</img> </img> </img> </img> </img>
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
Inside Dynamics AX 4.0: Licensing and Configuration Blog bot DAX Blogs 0 31.10.2007 11:40
Inside Dynamics AX 4.0: IntelliMorph Blog bot DAX Blogs 0 29.10.2007 16:50
Inside Dynamics AX 4.0: Security Blog bot DAX Blogs 0 29.10.2007 10:50
Inside Dynamics AX 4.0: RunBase Framework Extension Part III Blog bot DAX Blogs 0 02.10.2007 04:49
Часовой пояс GMT +3, время: 23:32.
