gatesasbait: New unified DateTime type in Dynamics Ax 5.0
Источник: http://gatesasbait.spaces.live.com/B...B9F5!150.entry
============== Good afternoon, Anyone that has experience with SQL has noticed that DAX versions prior to 5.0 handle date and time differently from SQL. Whereas SQL uses a single field to hold both date and time, DAX usees separate datatypes and fields for the two. It is no longer the case in version 5.0x as a new UtcDateTime datatype has been introduced. Microsoft has also renamed all timestamp fields to DEL_* (such as CreatedDate and CreateTime) and added corresponding unified fields (such as createdDateTime). Note that the original datatypes Date and Time are still available for use when only a time or a date is needed. Here's a quick job as example of tools available on the new datatype: static void UtcDateTimeExamples(Args _args) { UtcDateTime utcDateTimeNow = DateTimeUtil::getSystemDateTime(); ; info(strfmt("%1", utcDateTimeNow)); info(strfmt("%1", DateTimeUtil::date(utcDateTimeNow))); info(strfmt("%1", DateTimeUtil::time(utcDateTimeNow))); info(strfmt("%1", DateTimeUtil::applyTimeZoneOffset(utcDateTimeNow,DateTimeUtil::getUserPreferredTimeZone()))); info(strfmt("%1", DateTimeUtil::utcNow())); } ![]() ![]() Источник: http://gatesasbait.spaces.live.com/B...B9F5!150.entry
