Старый 09.05.2008, 04:40   #1
Dynamics AX: MSDW: What Will Be the Most Important Performance Enhancement in Dynamics AX 2009? Try Scaling of the AOS
Источник: http://dynamics-ax.blogspot.com/2008...important.html
Recently I created a new article for MSDynamicsWorld.com, and it is now posted and the top article right now. Check out the article here: Direct Link to: 'What Will Be the Most Important Performance Enhancement in Dynamics AX 2009? Try Scaling of the AOS'
This is part of my column on MSDynamicsWorld.com. You can view my entire column, by going here: My Column: 'AX Solution Outlook'
This article is the first in a series I hope to continue on the new performance improvements that await us in Dynamics AX 2009.
Check back soon!Find a job at: DynamicsAXJobs.com, also post a job for only $99.00!
Dynamics AX: SQL Sever 2008 - Performance with Dynamics AX 2009 - Resource Governor Blog bot DAX Blogs 0 23.01.2009 22:05
JOPX: Dynamics AX 2009 - Enterprise Portal link bonanza Blog bot DAX Blogs 0 27.11.2008 01:05
JOPX: Musings about Microsoft Dynamics AX 2009 Blog bot DAX Blogs 0 12.06.2008 23:06
Часовой пояс GMT +3, время: 14:08.
