Connection from AX to an External Database
Источник: http://alexvoy.blogspot.com/2008/11/...-database.html
============== There are a few options. We can create an ODBC connection on a local machine or just to connect directly without creating ODBC record. For exmaple, we want to check whether some records exist in an external table. We should create a OdbcConnection with appropriate LoginProperty and permit to execute a SQL statement by means of SqlStatementExecutePermission class. X++: server boolean checkExternalDB() { //connection parameters #define.ExternalTableName("CustTable") #define.ExternalFieldName("AccountNum") #define.ExternalSQLServerName("SRVAXSQL2005") #define.ExternalSQLDBName("DAXdb401_Standard_DEV") LoginProperty LP = new LoginProperty(); OdbcConnection myConnection; SqlStatementExecutePermission permission; Statement myStatement; str sqlStmt = ""; ResultSet myResult; boolean ret = true; ; LP.setServer(#ExternalSQLServerName); LP.setDatabase(#ExternalSQLDBName); try { myConnection = new OdbcConnection(LP); } catch { info("Check connection parameters. "+funcName()); ret = checkFailed(strfmt("External DB Connection error in: %1"), #ExternalSQLDBName); } myStatement = myConnection.createStatement(); //anything you want to get from the external table sqlStmt = "SELECT count (RecId) FROM "+#ExternalTableName+ " where "+#ExternalFieldName + " = '" + this.AccountNum+"'"; permission = new SqlStatementExecutePermission(sqlStmt); permission.assert(); myResult = myStatement.executeQuery(sqlStmt); while (MyResult.next()) { if (MyResult.getInt(1) > 0) { //yes, records exist in the external table ret = checkFailed(strfmt("@LBA53"+"\n"+funcName(), strfmt("[%1].[%2].[%3]", #ExternalSQLServerName, #ExternalSQLDBName, #ExternalTableName))); break; } } CodeAccessPermission::revertAssert(); return ret; }
