AX4 XML - Canonicalize and signing
Hi All
Are here developers from the UK? How to create IRMark during sending xml file to HMRC? I've generated an XML document and need to do the following: - Canonicalize (14N) the XML Document - Generate a 160-bit binary secure has from the canonicalized xml using SHA-1 algorithm - Encode the binary data using base-64 to produce a 28 characters string - Encode the binary data using base-32 to produce an easily humanreadable 32 characters string IRMark generation step by step is here http://www.hmrc.gov.uk/ebu/irmark-te...ep_by_step.pdf Thanks, Hugon
Hugon AX Developer .::. Beginner Последний раз редактировалось Hugon; 01.05.2009 в 14:59. |
Beacuse in Ax4 and later XML support is implemented based on System.XML namespace from .NET Framewoirk, I think, you can search for related terms for System.XML
For example, try to use http://msdn.microsoft.com/en-us/libr...rm(VS.80).aspx |
