Старый 02.05.2009, 14:06   #1
DeniZone: Show current configuration in title bar of windows
Источник: http://denizone.blogspot.com/2009/01...title-bar.html
This code snippet shows the current configuration of the AX client you have opened. Really helpful if you have several different AX clients opened at the same time.
void workspaceWindowCreated(int _hWnd)
   SqlSystem       sqlSystem = new SqlSystem();
   LoginProperty   loginProperty = sqlSystem.createLoginProperty();
   // Put workspace window specific initialization here.
   // Show application details in title bar
   if (loginProperty)
       WinAPI::setWindowText(_hWnd, strFmt("%1 - %2@%3 (%4)", WinAPI::getWindowText(_hWnd), loginProperty.getDatabase(), loginProperty.getServer(), this.currentAOLayer()));
blog, configuration utility, title, x++
gatesasbait: Showing Database name of current AOS in AX 4.0x title bar Blog bot DAX Blogs 0 18.12.2007 19:50
Inside Dynamics AX 4.0: Licensing and Configuration Blog bot DAX Blogs 0 31.10.2007 11:40
Client Axapta 3.0 SP4 и Linux. Как запустить? Daiver DAX: Администрирование 10 28.06.2007 15:59
axaptapedia: Configuration in title bar Blog bot DAX Blogs 1 08.03.2007 19:57
Часовой пояс GMT +3, время: 21:55.
