Старый 15.09.2009, 19:05   #1
axStart: Cleaning up your Virtual companies
Источник: http://axstart.spaces.live.com/Blog/...C0A0!562.entry
Often consultants create virtual companies and forget to trough away the old data. This can become an issue when migration to a newer version of dynamics AX gets involved. For example if the CustTable & VendTable become virtual, have the old data no PartyID number and the unique index on this column can’t be enabled. The easiest way for removing these obsolete records is using sql script.  I have added an example. Imagine a table collection with CustTable and VendTable. This table Collection is used in Virtual Company DMOV. Company DMO1 and DMO2 uses this virtual company. In case the records in CustTable and VendTable were not deleted for company DMO1 and DMO2, the next SQL script will help you:
deleteFROM [AX2009_SP1_Dev].[dbo].[CustTable] where DATAAREAID in('DMO1','DMO2')
deleteFROM [AX2009_SP1_Dev].[dbo].[VendTable] where DATAAREAID in('DMO1','DMO2')
But what happens if the customer decides not to use the virtual company any more. You could throw it away but the data is not deleted in the Database (is this a bug?) I have created a general script that throws away the virtual company.
declare @link_table nvarchar(255)
declare @local_table nvarchar(255)
declare @Statement nvarchar(300)
declare table_list cursorforselect  name fromsys.tables
open table_list
fetchnextfrom table_list into @link_table
while@@FETCH_STATUS= 0
begin
  BEGINtry
    SET @Statement =N'delete from [AX2009_SP1_Dev].[dbo].['+ @link_table  +'] where [DATAAREAID] in (''DMOV'',''ETC'')'
    print @Statement
    executesp_executesql@Statement
  endtry
  begincatch
    print @link_table  +' has no DATAAREAID'
  endcatch
end
close table_list
deallocate table_list
emeadaxsupport: How to set the number sequence for Global Address Book when virtual companies are used Blog bot DAX Blogs 0 24.08.2009 14:05
axaptafreak: Running Dynamics AX 2009 on Windows 7 using Windows Virtual XP Blog bot DAX Blogs 3 24.07.2009 11:20
Microsoft Dynamics CRM Team Blog: Building a Self-Contained Virtual CRM Development Server Blog bot Dynamics CRM: Blogs 0 05.05.2009 10:05
Microsoft Dynamics AX 2009 White Paper: Extending Default Cubes for Virtual Companies Vadik DAX: База знаний и проекты 0 31.03.2009 09:56
axStart: If X++ will act like c# Blog bot DAX Blogs 0 30.01.2009 16:05
Часовой пояс GMT +3, время: 11:00.
