Старый 27.01.2010, 17:12   #1
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1853 (69) ++++++++
Kernel rollup 978110 is available for Microsoft Dynamics AX 4.0 Service Pack 2
Problem that is resolved in kernel rollup 978110
A memory leak occurs when you run the master scheduling process
When you run the master scheduling process in Microsoft Dynamics AX 4.0, the Microsoft Dynamics AX Application Object Server services may consume lots of memory. Additionally, the memory is not released even though you exit the Microsoft Dynamics AX 4.0 client. This problem occurs if static containers are used in an object that is called from another class.
Ссылка на Partnersource
-ТСЯ или -ТЬСЯ ?
ax4.0, hotfix, kernel rollup, rollup, сводное планирование, скачать (download), утечка памяти
Kernel rollup 978429 is available for Microsoft Dynamics AX 4.0 Service Pack 2 Vadik DAX: База знаний и проекты 7 24.08.2015 14:43
Kernel rollup 975520 is available for Microsoft Dynamics AX 4.0 Service Pack 2 Vadik DAX: База знаний и проекты 0 18.01.2010 18:38
Kernel rollup 971558 is available for Microsoft Dynamics AX 4.0 Service Pack 2 Vadik DAX: База знаний и проекты 2 23.07.2009 00:01
Часовой пояс GMT +3, время: 04:40.
