Старый 12.03.2010, 15:05   #1
CRM DE LA CREME! Adding Http compression to ms crm
Источник: http://crmdelacreme.blogspot.com/201...to-ms-crm.html
1.Download and install the HttpModule from http://capitalhead.com/articles/enable-http-compression-for-your-aspnet-applications.aspx. Simply follow this link and download the binary package.
2.Extract the package and copy the extracted files into the CRMWEB bin folder.
blowery.Web.HttpCompress.dll
blowery.Web.HttpCompress.dll.xml
ICSharpCode.SharpZipLib.dll
ICSharpCode.SharpZipLib.dll.xml
3.Modify your Web.config
1.Add to the configSections
2.Add to the httpModules section inside system.web (if httpModules section does not exist, create it)
<span style="font-family:arial;">3.Add to the configuration section
CRM DE LA CREME! CRM 4.0 Disaster Recovery Blog bot Dynamics CRM: Blogs 2 26.02.2016 08:23
CRM DE LA CREME! Adding tooltips to CRM and help developers getting the attribute name using the tooltip Blog bot Dynamics CRM: Blogs 0 03.02.2010 10:05
CRM DE LA CREME! Adding sort order to the custom entities tab for security roles in MS CRM Blog bot Dynamics CRM: Blogs 0 29.01.2010 11:05
CRM DE LA CREME! Microsoft CRM 4.0 Update Rollup Best Practices Blog bot Dynamics CRM: Blogs 0 18.08.2009 11:05
Часовой пояс GMT +3, время: 22:45.
