Старый 23.07.2010, 16:05   #1
kamalblogs: Opening the Project node automatically in Dynamics Ax
Источник: http://kamalblogs.wordpress.com/2010...n-dynamics-ax/
Project Node is a very different node in terms of accessing, modifying and displaying it. If you want to automatically open a Project say after creating it through code you can’t use “AOTOpenNewWindow()” method. Instead you have to use “getRunNode” , refer example to understand better.
static void JobOpeningProjectNodeInAoT(Args _args)
    ProjectNode sharedProject = Infolog.projectRootNode().AOTfindChild('Shared');
    ProjectNode projectNode   = sharedProject.AOTfindChild('Docu');
    if (projectNode)
        projectNode.getRunNode();
kamalblogs: Opening Forms with Pre-applied filter using menuitem in Dynamics Ax Blog bot DAX Blogs 0 01.06.2010 08:06
kamalblogs: Storing and retrieving an XML in Resource node in Dynamics Ax Blog bot DAX Blogs 0 23.05.2010 02:12
Часовой пояс GMT +3, время: 21:40.
