Старый 04.08.2010, 15:07   #1
Evgeniy2020 is offline
Evgeniy2020
309 / 68 (3) ++++
Pre-upgrade duplication detection form
Здравствуйте,
Обнаружил что при переходе на ax 2009 с ax 3
в процеесе data upgrade, необходма тулзовина от Микрософта
Pre-Upgrade Duplicate Detection form, available on CustomerSource
Начальник имеющий доступ туда в отпуске, а сценарий upgrade нужно проверить как можно раньше.
если у кого есть вышлите пожайлуста в личную почту need.help06101984@gmail.com
спасибо
· Run the Pre-Upgrade Duplicate Detection form, available on CustomerSource, to identify any duplicate record IDs that exist in Ax 3.0 database.
The upgrade scripts for Microsoft Dynamics AX 4.0 and Microsoft Dynamics AX 2009 require that duplicate record IDs within a company do not exist. Duplicate record IDs within a company add unique index constraints into some of the tables in the Microsoft Dynamics AX 4.0 and Microsoft Dynamics AX 2009 databases. Duplicate record IDs may exist in Microsoft Dynamics AX 3.0 databases. To avoid running into problems during upgrade, the Pre- Upgrade Duplicate Detection form should be run on the Microsoft Dynamics AX 3.0 database before you run any upgrade scripts. The Pre-Upgrade Duplicate Detection form identifies any duplicate record IDs that exist in a Microsoft Dynamics AX 3.0 database. Download the .xpo file from the location below, and import it into your Microsoft Dynamics AX 3.0 system. Run the form to identify duplicates. You must resolve these duplicates before running any of the upgrade scripts.
http://go.microsoft.com/fwlink/?LinkId=137799
paruvella: Form browser for Dynamics Ax-Tables Blog bot DAX Blogs 0 26.06.2010 01:09
Kashperuk Ivan: Lookup form returning more than one value Blog bot DAX Blogs 0 29.01.2010 18:05
DynamicsAxSCM: Quality Management in Dynamics AX 2009 - Upgrade essentials Blog bot DAX Blogs 0 16.12.2008 14:05
casperkamal: Preventing a form getting added to "LastActivated Form" in Dynamics Ax Blog bot DAX Blogs 1 27.08.2007 23:17
Axapta Lessons: Trapping keystrokes in a Form Blog bot DAX Blogs 13 01.11.2006 18:16
Часовой пояс GMT +3, время: 20:38.
