Старый 15.09.2010, 17:05   #1
AX 2009 Technical Journal: Follow Up on Event ID 110 and 117 (annoying database error)
Источник: http://ax2009tech.blogspot.com/2010/...0-and-117.html
I wrote about this a while ago and since this still is what I call an annoying database error (noice) and something very common to AX 4.0/AX 2009 solutions, I would like to call on my readers to vote for a change in the AOS kernels (x32/x64) to filter out this information to prevent bombing the event log with errors not beeing errors at all. The voting can be done at Microsoft Connect.
Finally I would like to quote a paragraph in Microsoft KB article 143339:
Applications need to code their error handling routines for SQL Server connections to call SQLError() until it returns SQL_NO_DATA_FOUND, and act on any messages other than the ones that return a pfNative code of 5701 or 5703.
Maybe it's impossible to change this behaviour, but as long as Microsoft don't state this in their feedback on Connect, it's still an issue that I find hard to accept...
emeadaxsupport: Event 117 Changed language setting to us_english Blog bot DAX Blogs 0 10.05.2010 21:05
AX 2009 Technical Journal: Event ID 110 and 117 (annoying database error) Blog bot DAX Blogs 0 08.03.2010 16:05
Dianne Siebold: AX Tutorials in the AOT Blog bot DAX Blogs 0 05.12.2009 10:07
Часовой пояс GMT +3, время: 22:22.
