Старый 22.11.2010, 01:11   #1
25,644 / 848 (80) +++++++
xplusplus: strFmt function
Источник: http://xplusplus.info/index.php/strfmt-function/
the strFmt() function is used for formatting string values within a specific sentence or structure.
The first parameter is the format of the result string, with percent sign and the number of the argument to be placed in that position. The next parameters are the actual arguments.
For example, this line:
strFmt("%1 and %2 are %3","cat","dog","friends"); will return the following string: cat and dog are friends.
Another example is to print out an infolog message containing the current user id:
Info(strFmt("the current user id is: %1", curUserId())); The result will be “the current user id is USERNAME”.
East Ocean - Technical: SQL divide by zero "isZero" function Blog bot Dynamics CRM: Blogs 0 16.06.2010 10:05
SysDictCoder: Intrinsic function weirdness Blog bot DAX Blogs 3 11.02.2010 11:44
CRM Programmer: Upgrade of javascript function to hide "Add Existing ..." button Blog bot Dynamics CRM: Blogs 0 21.12.2009 20:05
CRM DE LA CREME! Some useful CRMform jscripts Blog bot Dynamics CRM: Blogs 0 02.09.2009 10:05
Не могу сформировать строку strFmt CasperSKY DAX: Программирование 9 17.04.2008 10:52
Часовой пояс GMT +3, время: 06:08.
