Старый 04.12.2010, 01:11   #1
dynamicsaxtraining: How to make data from temporary table available in form’s grid
Источник: http://www.dynamicsaxtraining.com/kn...e2%80%99s-grid
Code in form’s outer scope:
TmpTable tmpTable; FormRun formRun; ; ... // Fill tmpTable with data here … args.record( tmpTable ); formRun = classFactory.formRunClass( args ); formRun.init(); formRun.run(); formRun.detach(); formRun.wait(); if( formRun.closedOk() ) { … // Process data from tmpTable updated in form here … } Code in form, in the temporary table datasource – TmpTableDS:
public void init() { TmpTable tmpTable; ; tmpTable = element.args().record(); super(); TmpTableDS.setTmpData( tmpTable ); }
emeadaxsupport: Wrong data shown in the grid, if the table field is an Int 64 and the form control is an IntEdit instead of an int64edit. Blog bot DAX Blogs 3 22.07.2010 18:00
dynamicsaxtraining: Setup initial data (Vendor, Warehouse, Equipment) Blog bot DAX Blogs 0 07.12.2009 19:05
PatrickChua: Temporary table Blog bot DAX Blogs 0 04.05.2009 14:05
PatrickChua: Temporary table Blog bot DAX Blogs 0 28.10.2006 18:14
Часовой пояс GMT +3, время: 19:48.
