Старый 27.04.2011, 22:11   #1
dax-lessons: Create projects or sub projects using X++ [Dynamics AX]
Источник: http://dynamicsaxgyan.wordpress.com/...x-dynamics-ax/
Friends, below code will help you to create projects and sub projects using code. If there is already a parent project and we need to create sub projects based on the format which is already defined, the sample job below … Continue reading →
dynamics-ax: Interview with Microsoft's Lachlan Cash on his new role, AX 2012 and more Blog bot DAX Blogs 6 22.04.2011 14:55
Часовой пояс GMT +3, время: 07:25.
