Старый 22.09.2011, 20:11   #1
emeadaxsupport: Microsoft Dynamics AX 2012: Install multiple instances of Reporting Services extensions on the same machine
Источник: http://blogs.msdn.com/b/emeadaxsuppo...e-machine.aspx
With Microsoft Dynamics AX 2009 we do not support the setup where we have several instances of SQL Reporting Services on the same box connecting to different AOS. The reporting extensions always made connection to AOS mentioned in current configuration taken from Dynamics AX 2009 Configuration Utility. There is no way to change it. The only solution is to have several machines (virtualization).
Fortunately with Microsoft Dynamics AX 2012  it is changing. We have the way to implement it. The only requirements is that we have separate instance for each AOS to which we want to connect. More info you can find on TechNet site: http://technet.microsoft.com/en-us/l.../hh389760.aspx
--author: Czesława Langowska Vliegen --editor: Czesława Langowska Vliegen --date: 22/Sep/2011
axforum blogs: Квест: Подружим Dynamics Ax 2009 Sp1 RU7 c SharePoint Foundation 2010 Blog bot DAX Blogs 4 16.10.2017 17:50
crminthefield: Overview: Microsoft Dynamics CRM 4.0 Update Rollup 19 Blog bot Dynamics CRM: Blogs 0 26.08.2011 01:13
dynamics-ax: Microsoft Dynamics AX 2012 - BI Team and Reporting Blog bot DAX Blogs 0 17.05.2011 23:11
dynamics-ax: Modeling the world, with Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 25.01.2011 09:11
Часовой пояс GMT +3, время: 04:25.
