Старый 21.11.2011, 16:11   #1
axepclipboard: Bypass firewall and send files through Business Connector
Источник: http://feedproxy.google.com/~r/AxEpC...3/6KgA0k0YoyQ/
If you work with a separate servers for AOS and IIS it is likely that the AOS is behind a firewall, which means you cannot access the file directory. When you generate files using X++ code this will most likely be saved on the AOS server were the user that made the request from the [...]
Часовой пояс GMT +3, время: 11:44.
