Старый 28.12.2011, 19:11   #1
sumitsaxfactor: Defaulting Financial Dimensions [AX 2012]
Источник: http://sumitsaxfactor.wordpress.com/...sions-ax-2012/
Next in the series of posts on Ledger dimensions and Financial dimensions is defaulting or setting the financial dimensions for any record. Suppose you have a requirement wherein you need to create a customer via code and default specific dimension (say Employee) to this record.
In AX 2012 dimensions are not directly attached but the combination Record Id is stored. The name generally is DefaultDimension.
This field points to a record in DimensionAttributeValueSet table. This table holds the combination of financial dimensions that a particular record is attached to. The combination is stored in DimensionAttributeValueSetItem table.
The job below will help you in defaulting a dimension: I have put in enough comments to make the job self explanatory. This job will help you find / create a dimension combination record and get the record id to set.
staticvoid setDefaultFinancialDimension(Args _args)
    #LedgerSHA1Hash
    DimensionSHA1Hash               hash; //To store the calculated hash for DimensionAttributeValueSet
    HashKey                         valueKeyHashArray[]; //To store the has key of dimension in question
    Map                             dimAttrIdx; //to store the dimension index and backing entity type
    DimensionAttributeSetItem       dimAttrSetItem; // Contains the number of dimensions active for a account structure ledger
    DimensionAttribute              dimAttr; // Contains the financial dimensions records
    DimensionAttributeValue         dimAttrValue; // Contains used financial dimension values
    DimensionAttributeValueSet      dimAttrValueSet; //Contains default dimension records
    DimensionAttributeValueSetItem  dimAttrValueSetItem; //Contains individual records for default dimensions
    DimAttributeHcmWorker           dimAttrWorker; //Backing entity view for Employee type dimension
    DimensionEnumeration            dimensionSetId; //Record id for table that contains active dimensions for current ledger
    int dimAttrCount, i;
    int emplBackEntityType; //Stores the backing entity type for Employee type dimension
    //The employee backing entity will be the view DimAttributeHcmWorker
    emplBackEntityType = tableNum(DimAttributeHcmWorker);
    //Initialize the map to store the backing entity types
    dimAttrIdx = new Map(Types::Integer, Types::Integer);
    //Get the record Id (dimension set id) for current ledger to find active dimensions
    dimensionSetId = DimensionCache::getDimensionAttributeSetForLedger();
    //Find all the active dimensions for current ledger except main account and store there
    //backing entity type in the map
    whileselect * from dimAttr
        orderby Name
            where dimAttr.Type != DimensionAttributeType::MainAccount
        join RecId from dimAttrSetItem
            where dimAttrSetItem.DimensionAttribute == dimAttr.RecId &&
                dimAttrSetItem.DimensionAttributeSet == dimensionSetId
        dimAttrCount++;
        dimAttrIdx.insert(dimAttr.BackingEntityType, dimAttrCount);
    //initialize hash key array to null
<span><font face="Consolas"><font size="2">    for (i = 1<font color="#000000">; i
dynamics-ax: Interview with Microsoft's Lachlan Cash on his new role, AX 2012 and more Blog bot DAX Blogs 6 22.04.2011 14:55
palleagermark: Adding new financial dimensions to AX Blog bot DAX Blogs 1 17.02.2009 13:03
Часовой пояс GMT +3, время: 19:44.
