Старый 17.01.2012, 15:11   #1
palleagermark: Test target in unit tests
Источник: http://palleagermark.blogspot.com/20...nit-tests.html
When you set the SysTestTargetAttribute in a unit test case class, you should take care in assuring the validity of the attribute. There are no warnings or errors if your point to an element that does not exist.
If you run unit tests with code coverage, your test will be unresponsive for longer than expected. This is because the code coverage is calculated against the entire AOT if the element from SysTestTargetAttribute doesn't exist.
Click here, for the MSDN section on AX 2012 unit tests.
dynamicsaxtraining: Quality management Blog bot DAX Blogs 0 12.02.2011 00:11
mfp: AX6 sneak preview - X++ Unit test improvements Blog bot DAX Blogs 4 05.06.2009 10:56
Khue Trinh: AX 2009 Quality Management - Quality Control Blog bot DAX Blogs 1 04.07.2008 16:01
mfp: Late night discussions on software development #3: Unit testing Blog bot DAX Blogs 6 17.03.2008 12:01
axaptapedia: Unit Testing Blog bot DAX Blogs 0 19.11.2007 03:24
Часовой пояс GMT +3, время: 13:18.
