Старый 25.06.2012, 13:11   #1
palleagermark: Check if two layer nodes are in fact equal
Источник: http://palleagermark.blogspot.com/20...e-in-fact.html
Here's an example on how to check if two layers of a treenode match with no differences:
static void CompareTwoHighestLayers(Args _args)
TreeNode treeNode = TreeNode::findNode(@'\Data Dictionary\Tables\CustTable');
SysTreeNode node1;
SysTreeNode node2;
node1 = SysTreeNode::newTreeNode(SysTreeNode::getLayeredNode(treeNode, 0)); // 0 = Highest layer of the treenode
node2 = SysTreeNode::newTreeNode(SysTreeNode::getLayeredNode(treeNode, 1)); // 1 = Next highest layer of the node
info (strFmt("Equal (%1 %2): %3", SysTreeNode::getLayer(node1.parmTreeNode()), SysTreeNode::getLayer(node2.parmTreeNode()), SysCompare::silentCompare(node1, node2)));
palleagermark: Unable to create project with project filtering, for example, for a certain layer in AX 2009 RU-7? Blog bot DAX Blogs 1 28.10.2011 17:13
axzaptech: Dynamics AX2012 Fact boxes Blog bot DAX Blogs 0 24.08.2011 16:11
axinthefield: Recording manual check in Dynamics AX Blog bot DAX Blogs 0 18.06.2011 00:14
palleagermark: Troubleshooting missing EP Development Tools Blog bot DAX Blogs 0 02.07.2009 14:05
axaptapedia: Layer System Blog bot DAX Blogs 0 17.11.2007 05:45
Часовой пояс GMT +3, время: 23:13.
