Старый 06.01.2013, 21:50   #1
Anitha Roy is offline
Anitha Roy
Selected purchline records should pass to inventjournaltrans form
Hi All,
From last few days i'm stuck with one task.Can anyone please give the solutions for this issue.Advance Thank you...
Actually I created a form which will have only OPEN orders of purchlines.In that form i will have different purchlines with different ITEM's Id Ex.Item1,Item2,Item3 like this.and i have checkbox in the grid.If i select this checkbox in purchlines of multiple records and click Update Post(second form).The UpdatePost form will open and i click OK button in second form.The selected records should go to inventjournalstrans form(i.e Inventjournal lines).
NOTE:Example:-
i have items like item1,item2 etc. of purchlines in my form
if in my form i have 5 item1 records and 10 item2 record of purchline in a form then i should pass only 2 records in inventjournaltrans
1st record should be item1 with total or sum quantity of 5 records of item1 of purchlines in inventjournaltrans
2nd record should be item2 with total or sum quatity of 10 records of item2 of purchlines in inventjournaltrans
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
ax-erp: Pass Query from dialog to Form and Filter records Blog bot DAX Blogs 0 18.09.2012 18:11
dynamicsaxtraining: Paying a Vendor Blog bot DAX Blogs 0 22.03.2012 22:11
Kashperuk Ivan: Tool: Updating a field value for all selected records on a form Blog bot DAX Blogs 2 09.10.2011 20:18
Часовой пояс GMT +3, время: 02:40.
