Старый 22.01.2013, 03:12   #1
emeadaxsupport: When performing a find on a form for a control, the result does not include the complete path for the control
Источник: http://blogs.msdn.com/b/axsupport/ar...e-control.aspx
During
troubleshooting it is nice to know the navigational path to a control on a
form, for example a button which opens a new form. In Ax2012 when a find if
performed on the entire form the location of the control is not indicated as it
provides the listing in the designlist section only. To find the actual
location of the control this can be achieved by performing a find but it must
originate on the designs/design section of the form.
This differs from previous versions of Ax do to the designlist section not existing in previous versions
emeadaxsupport: Can't find the packing slip during invoice matching or is the invoice form not showing any order lines? Blog bot DAX Blogs 0 11.06.2012 22:13
emeadaxsupport: When deploying reports to a SQL Reporting Instance using a host header/clustered NLB hostname you get an error - The network path was not found Blog bot DAX Blogs 0 14.03.2012 08:11
Часовой пояс GMT +3, время: 23:54.
