Старый 27.02.2013, 01:12   #1
axStart: security on your ques
Источник: http://www.axstart.com/securityonyou...rityonyourques
Default Dynamics AX 2012 has a inhabit with cues on role centers. Would it not be great if on cue group with all cues needed for the business in it will fulfill on al role centers. In case you don’t have the rights on that cue, it will disappear? I think you like that.   Ques have security, but it is ignored in case used in que groups. (bug or missing feature?) From maintenance point of view live gets also easy. default ques for all my employees.
I dig into this issue and added 3 lines of code in default AX and it did the trick
how to configure it :
  1. create a cue Group in the AOT/Parts/Cue Groups
  2. drag all ques needed for the customer in that cue
  3. check if the que has a menu item that also has privileges
  4. incremental CIL compile
  5. add a cue object on the role center that needs ques. Set on properties of this que the que group name like you created.
  6. import the role center page bag into the AOT (SharePoint file , right mouse import page)
  7. mission accomplished.
Leon's CRM Musings: Bad CRM Security Habits To Break Blog bot Dynamics CRM: Blogs 0 09.02.2013 17:11
Sample Design Patterns: Book Give-away: 'Microsoft Dynamics AX 2012 Security How-To' Blog bot DAX Blogs 0 13.12.2012 01:13
axStart: Get in conrtol with Sharepoint DB names Blog bot DAX Blogs 0 29.08.2012 14:11
axinthefield: AX 2009 - How to Transfer Security Settings to another Server Blog bot DAX Blogs 0 24.06.2011 04:17
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
Часовой пояс GMT +3, время: 14:20.
