Старый 27.08.2013, 19:11   #1
emeadaxsupport: Purchase Order Confirmation greyed out
Источник: http://blogs.msdn.com/b/axsupport/ar...reyed-out.aspx
Issue : You unexpectedly experience that whenever you make a Purchase Order in Microsoft Dynamics AX2012 the Purchase Order is always of the type 'Draft' and Confirmation button is greyed out so you can not make a Purchase Order
Solution: Try to go to the module 'Procurement and sourcing/Setup/Parameters and note if you have the 'General' parameter 'Activate change management' marked
To enable the Purchase Order confirmation, try to unmark the above parameter and see if your confirmation button is now enabled when you make a new Purchase Order
The reason for this behavior has to do with the Change Management for Purchase Orders feature in AX 2012. You can find more information about this here
http://technet.microsoft.com/en-us/l.../hh802989.aspx
Unfortunately there is no easy way to 'correct' an already created Purchase Order in this case where the Confirm button is greyed out because the 'Activate change management' parameter was marked so the easiest would be to delete this Purchase Order and create a new one
ax-erp: Creation and Posting of Purchase order in MS Dynamics AX 2012 Blog bot DAX Blogs 0 06.11.2012 15:11
emeadaxsupport: Why Purchase order invoice did not post any transaction on the balance account for Accounts payable Blog bot DAX Blogs 0 06.09.2012 04:43
dynamicsaxtraining: Create purchase order Blog bot DAX Blogs 0 14.12.2009 14:05
Часовой пояс GMT +3, время: 19:24.
