Старый 12.11.2013, 19:11   #1
emeadaxsupport: Dynamics AX Enterprise Portal: How to unmark first record in AxGridView
Источник: http://blogs.msdn.com/b/axsupport/ar...xgridview.aspx
When the property AllowMarking is set up to true on AxGridView then it will always come with first row marked. Although it can be good in some cases but when we are adding the items to purchase requisition we do not want to have a first item already marked. To not get the first row marked we need to explicitly set the position on dataset datasource to -1:
public
void executeQuery()
super();
this.setPosition(-1);
So if we want to disable it as mentioned when adding items to purchase requisition we would need to add this.setPosition(-1) in DataSet PurchReqCatalogItems \ InventTable and would look like:
public void executeQuery()
this.addCatalogPolicyRule();
this.addCategoryAccesssPolicyRule();
inventTable_ds.query().clearCompanyRange();
inventTable_ds.query().addCompanyRange(buyingLegalEntity);
if (inventTable_ds.queryRun())
inventTable_ds.queryRun().query().clearCompanyRange();
inventTable_ds.queryRun().query().addCompanyRange(buyingLegalEntity);
super();
//added code
emeadaxsupport: Dynamics AX 2012 EP: Problem with installing Enterprise Portal " User cannot be found." Blog bot DAX Blogs 0 07.12.2012 23:12
emeadaxsupport: Microsoft Dynamics AX 2009 Enterprise Portal installation error Blog bot DAX Blogs 0 22.09.2011 20:11
emeadaxsupport: How does the Dynamics AX Setup detect existing AOS Instances? Blog bot DAX Blogs 0 06.07.2010 17:05
Часовой пояс GMT +3, время: 15:05.
