Старый 25.11.2013, 14:11   #1
emeadaxsupport: Slow performance when Configuration key turned off
Источник: http://blogs.msdn.com/b/axsupport/ar...urned-off.aspx
Description:
The configuration key Sales tax (ledgerbasicSalesTax) has been turned off in the system. When running example the retail statement posting, the performance is very poor.
The slow response is originated in every call to TaxParameters::find().
When analyzing the sql server queries we see a large number of Temporary table been generated which all take 150-200 msec.
Reason:
By design:
We have explained what is happening in this article.
http://msdn.microsoft.com/en-us/library/bb314749.aspx
TempDB Tables for
Disabled Tables
You can disable a regular
persisted database table by disabling the configuration key
that controls the table. Disabling the key causes the system to automatically
create a TempDB style of temporary table that matches the fields and schema of
the database table. This temporary table exists in the underlying SQL Server
database and is managed by the Application Object Server (AOS).
The purpose of automatically
creating this TempDB table is to enable AOT objects that reference the disabled
table to continue to compile and run. You can read and write to this TempDB
table even though the configuration key is disabled.
All table buffer variables
inherit the methods of the xRecord class. One such
method is setTmp, which creates an InMemory temporary
table that has the same schema as the regular table. However, the setTmp method cannot create an InMemory table from a TempDB
table. You can call the method isTempDb to determine
whether the setTmp method is available.
Solution:
Turn it on again.
In the example with sales tax use a tax percentage of 0,00% instead
Author: Kim Truelsen
Date: 25/11-2013
Старый 25.11.2013, 14:25   #2
trud is offline
trud
1,039 / 1635 (57) ++++++++
Записей в блоге: 1
Кстати прикольная тема
т.е. по сути советуют не отключать ключи на которых могут быть завязаны какие-нибудь таблицы.
а поскольку сложно понять что завязано, а что нет, то надо иметь все ключи включенными
у кого-нибудь есть идеи как с этим бороться?
Старый 25.11.2013, 14:40   #3
lvan is offline
lvan
Аватар для lvan
858 / 82 (4) ++++
Записей в блоге: 1
бороться с чем? вроде в статье есть Solution простой
Старый 25.11.2013, 14:43   #4
trud is offline
trud
Записей в блоге: 1
ну описанное solution - если вы отключили ключ, включите его.
причем приведен один пример, но такое же и будет с какими-нибудь RetailParameters, smmParameters и так далее
т.е. все это тоже придется включать
Старый 25.11.2013, 15:16   #5
gl00mie is offline
gl00mie
3,684 / 5813 (201) ++++++++++
Насколько я понимаю, проблема в том, что раньше было два типа таблиц - постоянные и временные (Regular и InMemory в терминологии AX 2012), и в куче мест проверка !buf.IsTmp() означала по сути проверку на то, является ли таблица постоянной. Потом добавили новый тип таблиц - TempDB, а кучу кода, который знал лишь про два прежних типа таблиц, не поменяли, вот этот код и сломался, поскольку теперь !buf.isTmp() не тождественно проверке на то, что "актуальный" тип таблицы - Regular.
Лежащий на поверхности способ подправить ситуацию - это приделать костылик в метод Company::createParameter(), который бы перед попыткой вставить запись проверял, какой у таблицы тип в AOT (Regular/InMemory/TempDB) и какой "актуальный" тип (isTmp(), isTempDB()), и пытался создать запись лишь в том случае, если таблица и задумана, и по факту является постоянной. Ну и, возможно, кэшировать результата этой проверки...
За это сообщение автора поблагодарили: trud (1).
Старый 25.11.2013, 15:45   #6
trud is offline
trud
Записей в блоге: 1
ну костылик поможет только частично
вот например код из smmParametersTable. при реализации костылика все равно будет выполняться
select firstonly parametersTable index key where parametersTable.Key == 1;
а при работе в CIL этот незамысловатый код даст довольно большую задержку.
вообще непонятна идея переводить отключенные таблицы на tempdb, чем просто временные не устраивали
public server static smmParametersTable find(boolean _forupdate = false)
    smmParametersTable parametersTable = null;
    if (parametersTable.isTmp())
        return parametersTable;
    parametersTable.selectForUpdate(_forupdate);
    // Find paramters table
    // If paramters table is not found it is created
    if (!parametersTable && !parametersTable.isTmp())
        // Use the generic framework for creating the parameters table
        Company::createParameter(parametersTable);
        //NumberSeqReference::construct(smmParametersTable::numberSeqModule()).load();
ax-erp: Choosing a Primary Key: Natural or Surrogate? Blog bot DAX Blogs 0 18.12.2012 02:11
Inside Dynamics AX 4.0: Licensing and Configuration Blog bot DAX Blogs 0 31.10.2007 11:40
Часовой пояс GMT +3, время: 12:36.
