Старый 29.05.2014, 14:11   #1
atinkerersnotebook: If You Don’t Like The Way Your Data Looks The Rename It
Источник: http://atinkerersnotebook.com/2014/0...the-rename-it/
Originally posted on Dynamics AX Tip Of The Day:
If you are as OCD about tidy data as I am, then you probably hate data that does not quite match up with everything else in the database. Maybe it’s because you made a mistake in adding some data, or maybe you just want the data to look a little cleaner, we don’t judge. Luckily you don’t have to live with odd data within Dynamics AX, you can rename the records at any time and all of the related records will be renamed as well.
If it’s good enough for Gordon Matthew Thomas Sumner then it’s good enough for your data.
View original 122 more words
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
atinkerersnotebook: Using the Dynamics AX Excel Add-In Blog bot DAX Blogs 1 25.09.2013 07:11
atinkerersnotebook: Using Power BI to Visualize Customer Saturation Blog bot DAX Blogs 1 07.08.2013 08:11
Часовой пояс GMT +3, время: 02:40.
