Старый 22.06.2014, 01:19   #1
emeadaxsupport: Slow opening of form "Business relations details" after updating to MS Dynamics AX 2009 SP 1 RU 8
Источник: http://blogs.msdn.com/b/axsupport/ar...sp-1-ru-8.aspx
If you work with a reasonable amount of companies per database (>20) then it might take nearly 1 minute to open form "Business relations details" by pressing button function "Convert to customer" or "Convert to vendor"
Creating the following index may speed up the process quite a lot. So check it out in your test environment first if you like:
“Microsoft provides programming examples for illustration only, without warranty either expressed or implied, including, but not limited to, the implied warranties of merchantability or fitness for a particular purpose. This mail message assumes that you are familiar with the programming language that is being demonstrated and the tools that are used to create and debug procedures.”
Table address
Index Name: RedIDDataAreaID
Index fields: RecID, DataAreaID
Important note: Please be aware that the filed sequence in the new index is important!
DAX: Microsoft Dynamics AX 2012 R3 is now available! Blog bot DAX Blogs 1 02.05.2014 23:00
emeadaxsupport: Translated User Help on TechNet and downloadable New Features lists available! Blog bot DAX Blogs 0 31.01.2013 05:11
emeadaxsupport: Checking Database entries after restoring a Microsoft Dynamics 2009 SQL Database to another Domain or Environment Blog bot DAX Blogs 0 18.02.2010 23:05
Часовой пояс GMT +3, время: 07:22.
