Старый 25.09.2014, 21:12   #1
emeadaxsupport: How to always open the Role Center on startup
Источник: http://blogs.msdn.com/b/axsupport/ar...n-startup.aspx
Role Centers are role-specific home pages that provide an overview of information that pertains to a user's job function in the business or organization. With Dynamics AX 2012, when a user logs in, the application displays the area page of the last visited module, and not the Home/Role Center page.
Dynamics AX 2012 was designed this way as most of the users prefer to find the application where they left it, and don't want to have to navigate back to the module they were using.
Unfortunately there isn't any parameter to change this behavior and some customers would like to always have the Home/Role Center displayed when they log in.
We thought about various workarounds to make this working so the Role Center always displays on login, and the simplest seems to be the following:
  1. Open a Developer workspace
  2. In the AOT, find the class named Application
  3. Double-click the startup method
  4. Add the following line of code at the end of the method: infolog.navPane().selectedGroup('Home');
  5. Save and compile
I hope this is helpful!
Bertrand
emeadaxsupport: How to perform a data center change (change of the physical location) where a SQL server 2008 R 2 cluster installation and MS Dynamics AX 4.0 is involved? Blog bot DAX Blogs 0 21.06.2014 19:19
emeadaxsupport: Resolving some issues you may experience when creating an AX 2009 Role Center and Enterprise Portal Site using SharePoint Server/Foundation 2010 after installing Microsoft Dynamics AX 2009 SP1 hotfix 2278963 Blog bot DAX Blogs 1 24.09.2010 11:34
emeadaxsupport: How can the Role Center be individually turned off? Blog bot DAX Blogs 0 14.07.2010 01:05
emeadaxsupport: Role Center is no longer showing up after installing an Application Roll-Up package Blog bot DAX Blogs 0 08.06.2010 19:05
Часовой пояс GMT +3, время: 16:33.
