Старый 18.10.2014, 17:11   #1
mfp: Trace Parser: NULL::inner–explained
Источник: http://blogs.msdn.com/b/mfp/archive/...explained.aspx
If you have analyzed AX traces in the Trace Parser, you most likely came across something like this during your efforts:
First time I saw it, I was puzzled – an object named “NULL” with a method named “inner”, I’ve never heard of that before – what is it? I started asking around, no one seemed to know. Bing didn’t help me either. I did a search in our source files, it gave me more hits than I wanted to explorer. About to give up, it struck me, that the name is not too bad for a method that doesn’t exists on an object and is inside the caller.
So the answer is simple and straight forward. "NULL::inner” is used for all embedded methods in X++ when shown in the trace parser. Navigating to the caller in the Trace Parser also clearly shows that an embedded method exists (with the name “doEscape()”).
As a side note, I can mention that the Call Stack window in the X++ Debugger doesn’t include embedded methods.
emeadaxsupport: Trace Parser Tip - How to find a SQL statement across all sessions Blog bot DAX Blogs 0 24.12.2013 14:11
axperf: Microsoft Dynamics AX 2012 Trace Parser is now available for AX 2009 customers Blog bot DAX Blogs 2 01.12.2011 14:54
axperf: Walk through major features of Microsoft Dynamics AX 2012 Trace Parser (Part 2) Blog bot DAX Blogs 0 07.09.2011 03:19
axperf: Event Trace Parser Tool for Microsoft Dynamics AX Released Blog bot DAX Blogs 0 20.06.2009 10:05
Часовой пояс GMT +3, время: 09:19.
