Старый 20.11.2014, 11:11   #1
axcoder: Static code analysis using XLNT
Источник: http://axcoder.blogspot.com/2014/11/...sing-xlnt.html
In ax 2012 there is a code upgrade tool based on parser named XLNT - it allows to use syntax tree if X++ from .NET.
I have written a small example of static analysis for X++ based on that technology http://1drv.ms/1u9Rs8x
It detects code patters that are likely to be copy-and-paste errors (when somebody copies code but forget to change something in a copy) like:
case X: some code
case X: some code
Код:
if (x) {
   y
else
   y
Последний раз редактировалось mazzy; 20.11.2014 в 11:30.
Microsoft Dynamics CRM Team Blog: Check your JavaScript code to prepare for your upgrade Blog bot Dynamics CRM: Blogs 0 24.08.2013 04:19
axcoder: Code folding in ax 2012 Blog bot DAX Blogs 0 10.04.2012 02:11
axcoder: Syntax highlighting of X++ code in your blog or site Blog bot DAX Blogs 0 16.01.2008 15:00
Вопрос про Demand Planner slava09 DAX: Функционал 4 25.09.2006 11:43
Часовой пояс GMT +3, время: 09:57.
