Старый 07.02.2015, 18:15   #1
25,644 / 848 (80) +++++++
emeadaxsupport: Adding Exchange Rates using the AIF LedgerExchangeRateService Service
Источник: http://blogs.msdn.com/b/axsupport/ar...e-service.aspx
The following is a quick example that may help if you need to add an Exchange Rate to an existing Currency Pair in Microsoft Dynamics AX 2012 R3 using the AIF LedgerExchangeRateService service. I ran into a couple snags along the way and finally was able to insert data correctly in AX using the below. When you create the AIF Inbound Port for this service, I recommend to enable logging under the Troubleshooting section in case you need to review the XML that is created.
C# Console Application Example
The goal in the support case was to add an Exchange Rate to at an already existing Currency Pair (EUR to USD) pair.
The code below adds a new Exchange Rate to this existing Currency Pair.
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using UpdateExchangeRateTester.ERService;
namespace UpdateExchangeRateTester
class Program
static void Main(string[] args)
ExchangeRateServiceClient proxy = new ExchangeRateServiceClient();
CallContext cc = new CallContext();
cc.Company = "USMF";
// Call Read First per http://community.dynamics.com/ax/f/33/t/75714.aspx
//Criteria will be the From and To for the CurrencyPair (EUR to USD)
QueryCriteria qc = new QueryCriteria();
qc.CriteriaElement = new CriteriaElement[2];
qc.CriteriaElement[0] = new CriteriaElement();
qc.CriteriaElement[0].FieldName = "FromCurrencyCode";
qc.CriteriaElement[0].DataSourceName = "CurrencyPair";
qc.CriteriaElement[0].Value1 = "EUR";
qc.CriteriaElement[1] = new CriteriaElement();
qc.CriteriaElement[1].FieldName = "ToCurrencyCode";
qc.CriteriaElement[1].DataSourceName = "CurrencyPair";
qc.CriteriaElement[1].Value1 = "USD";
EntityKey[] keylist = proxy.findKeys(cc, qc);
AxdLedgerExchangeRate axdExchangeRate = proxy.read(cc, keylist);
foreach (AxdEntity_CurrencyPair currencyPair in axdExchangeRate.CurrencyPair)
currencyPair.action = AxdEnum_AxdEntityAction.update;
currencyPair.actionSpecified = true;
currencyPair.RateType = null; // do not send in a CurrencyPair RateType on updates
//create new exchange rate
AxdEntity_ExchangeRate newExchangeRate = new AxdEntity_ExchangeRate();
newExchangeRate.ExchangeRate = 95.60M; //AX value is .95600
newExchangeRate.ExchangeRateSpecified = true;
newExchangeRate.ValidFrom = new DateTime(2015, 2, 5);
newExchangeRate.ValidFromSpecified = true;
newExchangeRate.action = AxdEnum_AxdEntityAction.create;
newExchangeRate.actionSpecified = true;
currencyPair.ExchangeRate = new AxdEntity_ExchangeRate[1] { newExchangeRate };
try
proxy.update(cc, keylist, axdExchangeRate);
Console.WriteLine("Update Call Complete");
catch (Exception e)
Console.WriteLine(e.Message);
Console.WriteLine("The AxdLedgerExchangeRate was not updated.");
Console.ReadLine();
A couple items I had to do was set the RateType to null on the AxdEntity_CurrencyPair object otherwise I was receiving an AIF Exception on RateType. I also did not send the existing Exchange Rate data in the AxdEntity_ExchangeRate[] collection.I just created a new AxdEntity_ExchangeRate with the action property set to create. The final result looks like what I wanted to achieve with a new Exchange Rate added with correct dates:
XML Example
This is the XML document that AIF processes from the C# Console Application. You can use this as a starting point if you need to know what the XML schema should look like if you need to create XML for a File Adapter Inbound port.
RecId
22565423204
Original
USMF
2015-02-05T00:00:00Z
http://www.w3.org/2001/XMLSchema-instance">
AsOf
911f6653fc2da5d3ce42d69fb95f7269
22565423204
1
EUR
USD
Average
One
95.60
2015-02-05
atinkerersnotebook: Configuring Automatic Exchange Rates in Dynamics AX 2012 Blog bot DAX Blogs 0 21.09.2013 17:12
atinkerersnotebook: Using Service Management to Track Service Orders Blog bot DAX Blogs 1 25.08.2013 19:16
AIF: Microsoft Dynamics AX Services and Windows Azure Service Bus Blog bot DAX Blogs 0 24.07.2013 03:13
emeadaxsupport: AX for Retail 2012 R2: Installing the Real-time Service Blog bot DAX Blogs 0 19.12.2012 11:11
emeadaxsupport: How to: Add a new operation to AIF Document Service. Blog bot DAX Blogs 0 01.04.2011 00:12
Часовой пояс GMT +3, время: 05:37.
