Вернуться   AXForum > Microsoft Dynamics NAV > NAV: Прочие вопросы
Старый 18.05.2005, 02:52   #1
Sometimes users of Navision have no or little understanding of how filters and keys works in the application.
This little utility can help in those installations, where users keep setting filters on large tables and forgets to remove them again or select a better key. When opening a list of 100000's of records and the key or filters are set incorrectly or inefficiently, then this small routine can assist the user in opening the form correctly without inefficient filters.
There is one little catch to the setup, and that is that you have to modify all forms where the above-mentioned problems are most likely to occur. In standard Navision this could be i.e. posted invoices, BOMs, Change log and so on.
Have fun with it and let me know if something is missing or if any questions arises.
The objects are v4.0, but I included the text format, so you can easily downgrade it to earlier versions supporti ng RecordRef variables.
Use it as your on risk. No guaranties what-so-ever.
http://mibuso.com/dl.asp?FileID=486&Type=file
Часовой пояс GMT +3, время: 18:02.
