Старый 31.10.2007, 16:59   #1
This is an update release of COM Encoding Converter. This new release has a installer and convert function has renamed to avoid problems with reserved word in VBA. (Thanks to Mark Brummel)
You can also manually register component.
To manually register your components you can make
regasm.exe COMEncodingConverter2.dll /tlb:COMEncodnigConverter2.tlb
Regasm is located in c:WINDOWSMicrosoft.NETFrameworkv2.0.50727
To Use object
Create am automation variable : aEncConv Automation 'COMEncodingConverter2'.EncodingConverter2
CREATE(aEncConv);
aEncConv.ConvertFile('UTF-8', 'Windows-1252', 'C:input.txt', 'Cutput.txt');
Download is available in http://dynamicsuser.net/files/folders/nav_...entry94046.aspx
Подробнее... http://dynamicsuser.net/blogs/nunomaia/arc...onverter-2.aspx
Часовой пояс GMT +3, время: 16:16.
