Старый 04.05.2008, 10:40   #1
25,644 / 848 (80) +++++++
в†ђOlder revision
Revision as of 06:40, 4 May 2008
Line 1:
Line 1:
There are many different mechanisms to connect NAV and an external database. Before you can determine which method is best for you, you need to carefully understand the [[ Interfacing to NAV|Business needs]] of the interface. Here we discuss the technical interface components, and some cases where they are appropriate. There are many different mechanisms to connect NAV and an external database. Before you can determine which method is best for you, you need to carefully understand the [[ Interfacing to NAV|Business needs]] of the interface. Here we discuss the technical interface components, and some cases where they are appropriate.
{{WIP}} {{WIP}}
==Connection Classifications== ==Connection Classifications==
We can look at four general classes of interfaces. Though we could consider the first three to be different views of the same general concept).: We can look at four general classes of interfaces. Though we could consider the first three to be different views of the same general concept).:
Источник http://wiki.dynamicsbook.com/index.php?tit...ternal_Database
Часовой пояс GMT +3, время: 03:42.
