Старый 09.02.2014, 18:22   #1
The "About this page" is very handy to have some info about the page and the table of that page.
But it doesn’t work on a subpage. If I select "About this page", it always shows me the info of the main page.
It is possible to do it, and it is quite easy too : When you hover over the "About this page", it shows you the shortcut-keys : CTRL+ALT+F1 (not exactly an easy one to remember and even less to use!) (BTW: did I already advice you to spend some time to learn the shortcuts of NAV? You will work a lot faster using them!)
Knowing this shortcut, you just have to go to a field on the subpage and then hit the shortcut combo and you will have info on your subpage.
Читать дальше
Часовой пояс GMT +3, время: 00:09.
