Microsoft Dynamics CRM Team Blog: Creating a Codeless Opportunity Payment Schedule in CRM
Источник: http://blogs.msdn.com/b/crm/archive/...le-in-crm.aspx
============== Today's post is brought to you by guest blogger Leon Tribe, CRM MVP. Leon's musings about CRM and other tech can be found on his blog. Thanks Leon! The new calculated fields provide a lot of opportunity for codeless configuration in Dynamics CRM. In this example I will walk through creating an automated payment schedule in CRM for an Opportunity using calculated fields and Dialogs. Business Case For larger sales, we sometimes stagger payments over a period of time. Perhaps this is a lease-purchase arrangement or maybe a lay-by payment system. While, in theory, aspects such as interest, deposits and final lump payments could also be incorporated, I will leave these as an exercise for the reader. The Key Entities For this example, I will work with two entities: Opportunities and a custom child entity called Payments. In terms of the fields I am using we have:
The Calculations The formulae for the calculated fields are: Amount Remaining ![]() Due On ![]() Payment Amount ![]() In theory, with the values we set on the Opportunity and the Payment Number, all other numbers can be calculated. ![]() Automating with Dialogs In principle, we could leave the solution there and manually create Payment records from the Opportunity. Assuming we map the fields down from the Opportunity to the Payment entity, all we need do is create a new Payment record from the Opportunity, enter the Payment Number and the system will do the rest. However, for a schedule with 100 payments, this is a lot of work. This is where Dialogs come to the rescue. With Dialogs we can automate the creation of all Payment records. To do this I will create two Dialogs:
The Payment Scheduler looks like this: ![]() Both Dialogs run from the Opportunity entity. In this one we confirm the four key constants, held on the Opportunity (Total Amount, Start Date, Days Between Payments and Total Payments) and write them back to the Opportunity with the Update step. ![]() For some reason I could not get the Estimated Revenue to appear for the Prompt and Response default value, even though I could display it as part of the prompt. If this is a problem, you may need to create a separate Total Amount field. We then create the first Payment. ![]() Finally we call our looping Dialog to create the rest of the Payment records, passing it the total number of Payments. The looping Dialog looks like this: ![]() Firstly, it takes in the previous Payment’s number and if the last Payment was the final Payment i.e. Payment Number = 1, the Dialog ends. If this is not the case a new Payment record is created. ![]() We then update this record to reduce the Payment Number by one. ![]() The next step in our Dialog is a bit of a dirty trick. We want to loop the Dialog but we do not want a Dialog page to appear many times. Every Dialog requires a Page with an associated Prompt and Response so, to meet this criterion, we embed it in an If-Statement which will never succeed (in my case the associated Opportunity name must be blank, which will never be the case). Once past this, the Dialog calls itself passing through the Payment’s Payment Number. The Final Result The end result is a set of Payments against the Opportunity, evenly dividing the Opportunity total across all Payment records. If we want to keep track of when payment are actually made, we could add additional fields like a receipt number field or a simple tick box. To create the Payment records, the user simply fires up the Dialog from the Opportunity. ![]() Then, after making sure the four fields have values, they click Next and the Dialog shows its Finished screen. ![]() After clicking Finish, the Opportunity now has a full set of Payments against it. ![]() Conclusions While a simple application of the tools, this shows how combining Dynamics CRM functions like calculated fields and Dialogs can create very powerful and intuitive tools for the user. In the past creating a tool like this for the user required plugins and extensive development with limited capacity for maintenance by the CRM Administrator. With this approach the CRM Administrator gets complete control of the tool and its behavior. Thanks, Leon Tribe | LinkedIn | Twitter Источник: http://blogs.msdn.com/b/crm/archive/...le-in-crm.aspx
