Старый 05.03.2016, 13:11   #1
Afna CRM: Do not name the action parameter "Error"
Источник: http://a-crm.blogspot.com/2016/03/do...ter-error.html
If you create an output action parameter named "Error" and you assign a value to it using "Assign Value step" the action will be published normally, but when trying to execute it, you will get the message:
The following errors were encountered while processing the workflow tree:
'DynamicActivity': The private implementation of activity '1: DynamicActivity' has the following validation error: Compiler error(s) encountered processing expression
Just rename the parameter and the error will be gone.
CRM DE LA CREME! CRM 4.0 Disaster Recovery Blog bot Dynamics CRM: Blogs 2 26.02.2016 08:23
Gareth Tucker: MyCRM add-ons for Microsoft CRM 2011 Blog bot Dynamics CRM: Blogs 0 06.07.2012 18:11
Leon's CRM Musings: Book Review: Microsoft Dynamics CRM 2011 Administration Bible Blog bot Dynamics CRM: Blogs 0 19.12.2011 12:11
Все о Microsoft Dynamics CRM: Как установить Microsoft Dynamics CRM 2011 Beta Blog bot Dynamics CRM: Blogs 0 31.10.2010 15:08
Часовой пояс GMT +3, время: 13:35.
