Старый 09.05.2016, 17:16   #1
emeadaxsupport: Module access level – specify which users can post to a period in AX 2012
Источник: https://blogs.msdn.microsoft.com/axs...od-in-ax-2012/
In AX 2012, it is possibly to specify which user groups are allowed to post accounting transactions to a certain period for a given module by using the Ledger calendar form. The form is found in General Ledger>>Set up>>Ledger>>Ledger Calendar>>Module access level (please see screen shot below). Here, you can specify if All, None or... Read more
emeadaxsupport: How to install and set up integration with MS Project in AX 2012 R3 successfully the first time Blog bot DAX Blogs 0 25.09.2015 19:14
emeadaxsupport: Form created in e.g. AX 2012 RTM or AX 2012 R2 with ManagedHost control on its design fails to open on AX 2012 R3 Blog bot DAX Blogs 0 21.09.2015 19:11
emeadaxsupport: Translated User Help on TechNet and downloadable New Features lists available! Blog bot DAX Blogs 0 31.01.2013 05:11
Часовой пояс GMT +3, время: 17:57.
