Старый 12.05.2016, 14:11   #1
palleagermark: A dynamic strFmt call
Источник: http://www.agermark.com/2016/05/a-dy...rfmt-call.html
In the communities a users asked about a way to make a dynamic strFmt call, not knowing the number of parameters up front.
With some good critical tests from Levgen Miroshnikov (blog) I think I have managed to write a class method that does that.
Regular StrFmt will round decimal value and change the decimal point to whatever fits your windows locale. This method has a parameter allowing you to keep the formatting of decimal values.
Here is the code for it:
public str dynamicStrFmt(
str _expression,
container _args = conNull(),
boolean _keepRealsDecimals = false)
str ret;
Counter counter;
str argStr;
char argChar;
if (_args == conNull())
return strFmt(_expression);
for (counter = 1; counter
axmfg: More about (dynamic) negative days Blog bot DAX Blogs 0 19.02.2015 23:16
emeadaxsupport: Enabling the new Call Center Channel User Functionality in AX 2012 R3 Blog bot DAX Blogs 0 02.09.2014 18:11
palleagermark: Call a BOF service with a caller record Blog bot DAX Blogs 0 04.11.2011 17:12
Gareth Tucker: Call Centre Optimised CRM–An Example Solution Blog bot Dynamics CRM: Blogs 0 07.09.2011 17:11
palleagermark: Dynamic date ranges in queries Blog bot DAX Blogs 8 07.05.2008 17:03
Часовой пояс GMT +3, время: 07:33.
