Старый 06.08.2016, 03:27   #1
25,644 / 848 (80) +++++++
organicax: Coverage group – explosion time fence
Источник: https://organicax.com/2016/08/05/cov...on-time-fence/
When setting up the coverage groups for your items you need to consider the setting you have on your groups to reflect how you want plan for the related raw materials for the product. When doing this you need to consider the lead time of your components. For example if you set the explosion fence shorter than the lead time to either make or purchase your raw materials then the system won’t explode the finished goods so you see the requirement for the raw materials in time. Which will mean that you might be understocked when it comes time to make the finished good. So the explosion time fence is something to consider. Because you also don’t want to set it out too far in the future that the system will just be doing work exploding the materials needs but you won’t be looking at that data. So consider how you use the explosion time fence to match your planning needs.
Here is a quick overview.
AX2012 R3 CU10
Cheers
Lachlan
Filed under: Supply chain planning
axmfg: More about (dynamic) negative days Blog bot DAX Blogs 0 19.02.2015 23:16
emeadaxsupport: AX for Retail 2012 R2: Installing the Real-time Service Blog bot DAX Blogs 0 19.12.2012 11:11
fed: Net requirements update in MRP Module and Working Set of MRP Blog bot DAX Blogs 14 08.05.2012 13:09
NAV Team: Time zones usage in Microsoft Dynamics NAV web services Blog bot Dynamics CRM: Blogs 0 11.01.2011 13:40
axaptapedia: Current Time Blog bot DAX Blogs 1 29.11.2010 22:11
Часовой пояс GMT +3, время: 14:20.
