Старый 12.08.2016, 17:11   #1
25,644 / 848 (80) +++++++
palleagermark: Don't change the name of a Form instance in AX 7
Источник: http://www.agermark.com/2016/08/dont...nce-in-ax.html
In AX 2012 you could do something like this, where you change the name of a Form instance:
form = new Form(formstr(MyPrettyForm));
form.name("AnotherNameToConfuseEverybody);
args = new Args();
args.object(form);
formRun = classfactory.formRunClass(args);
etc...
In AX 7 changing the name seems to confuse AX to a sense where it can't figure out to actually run eventual code in (at least) the init and run methods of the form.
For many reasons I think it is a poor idea to change the name of a form instance, now there is also a technical reason not do it.
emeadaxsupport: AX Performance Troubleshooting Checklist Part 1B [Application and AOS Configuration] Blog bot DAX Blogs 0 05.09.2014 21:11
daxdilip: Tip - How to Retrieve AOS Instance name in Dynamics AX via X++ Code Blog bot DAX Blogs 0 24.11.2011 11:11
msdax: Users don't want to delete their usage data - but you've redeveloped the form - the solution - EMEA Dynamics AX Support - Site Home - MSDN Blogs Blog bot DAX Blogs 0 28.04.2011 04:27
Часовой пояс GMT +3, время: 06:44.
