Старый 29.09.2016, 11:11   #1
msdn.microsoft.com/nav: Design Pattern: Security – Single Point of Access
Источник: https://blogs.msdn.microsoft.com/nav...int-of-access/
Context: Protected data needs to be used. There are many types of entities which might attempt to use the data. Problem: If no standard way of accessing data exists, then each entity might attempt to build its own system for handing the sensitive data. The data access layer might be implemented over and over again...
NAV Team: How to: Set up your Microsoft Dynamics NAV installation for Single Sign-on with Office 365 using Windows PowerShell Blog bot Dynamics CRM: Blogs 0 19.12.2013 15:10
emeadaxsupport: Preliminary Microsoft Dynamics AX 2012 R2 content now on TechNet and MSDN! Blog bot DAX Blogs 0 10.11.2012 08:20
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics NAV 2009 SP1 Blog bot Dynamics CRM: Blogs 0 11.06.2010 16:33
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics NAV 2009 Blog bot Dynamics CRM: Blogs 0 04.06.2010 13:21
Clausl: Action and Activity Button icons in Microsoft Dynamics NAV 2009Копирование Stream Blog bot Dynamics CRM: Blogs 0 26.11.2008 17:15
Часовой пояс GMT +3, время: 11:04.
