Старый 24.10.2016, 23:11   #1
gustafwesterlund: Extending Max amount of components on dashboards only for onprem
Источник: http://gustafwesterlund.blogspot.com...onents-on.html
Some of you might have found some sites like this https://msdynamicscrmblog.wordpress....s-crm20112013/
one:
I, Soupeurfaive, via Wikimedia Commons
or even the original MSDN or Technet sites regarding how to be able to change the maximum amount of components on a dashboard from the maximum of 6 to for instance 8 using PowerShell.
On the MSDN and Technet pages there are some default CRM version text in the header and footer but make no misstake, you can only do this change in a CRM onprem environment where you are the deployment admin.
As the change is deployment wide and you need to have deployment administrator access rights, you are also extremely unlikely (unless you have a dedicated Online environment) to get that set.
Gustaf Westerlund
MVP, Founder and CTO at CRM-konsulterna AB
www.crmkonsulterna.se
DynamicsAxSCM: Change license plate, split quantity, skip and override location during inbound put away Blog bot DAX Blogs 0 27.11.2015 16:11
emeadaxsupport: Connecting Retail Components on an External Computer to the Microsoft Dynamics AX R3 Azure Lifecycle Services Demo Virtual Machine Blog bot DAX Blogs 0 28.06.2014 00:13
crminthefield: Creating SSL Certificates for CRM Test Environment Blog bot Dynamics CRM: Blogs 0 10.12.2013 02:12
Leon's CRM Musings: Extending Dashboards Without Code Blog bot Dynamics CRM: Blogs 0 16.10.2011 16:14
Часовой пояс GMT +3, время: 17:37.
