Старый 14.11.2016, 21:11   #1
25,644 / 848 (80) +++++++
organicax: Creating a new model file
Источник: https://organicax.com/2016/11/14/cre...ew-model-file/
If you are just starting out with D365 or moving from AX2012 then it helps to have a little orientation on where to find things. If you are coming from AX2012 then you will have a lot of basic concepts that still apply in D365 but there are new ways to do things.
When starting development you will need to create a new model. A model can be used to package up the development we are doing so you can later deploy to an environment. To actually do work within Visual Studio you will need to create a project. A project is like any other Visual Studio in that it organizes the items you are working on.
D365FO 1611 – Update3 (7.0.4307.16141)
If you are starting our with D365 development this is a good help topic page to start with
Developer home page</p>
Cheers
Lachlan
Filed under: Development, Microsoft Dynamics AX
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics NAV 2013 Blog bot NAV: Blogs 0 15.05.2016 18:12
DynamicsAxSCM: Change license plate, split quantity, skip and override location during inbound put away Blog bot DAX Blogs 0 27.11.2015 16:11
crminthefield: Creating SSL Certificates for CRM Test Environment Blog bot Dynamics CRM: Blogs 0 10.12.2013 02:12
Microsoft Dynamics CRM Team Blog: Creating and Publishing a Web Portal to an Azure Cloud Service Blog bot Dynamics CRM: Blogs 0 17.04.2013 23:11
Часовой пояс GMT +3, время: 11:44.
