Старый 31.03.2017, 02:14   #1
25,644 / 848 (80) +++++++
organicax: D365 Warehouse app configuration settings.
Источник: https://organicax.com/2017/03/30/d36...tion-settings/
In a previous post we had a look at the basic download and install of the D365 Warehouse app. If you want to use it in your environment then you will have to change the configuration settings. This requires a few steps and if you don’t have access to your Azure AD then you might need to get someone else to configure that part and give you the settings.
Here is a quick overview.
D365FO
If you want to see the setup written down you can refer to the help wiki here
https://ax.help.dynamics.com/en/wiki...s-warehousing/
Cheers
Lachlan
Filed under: Warehouse management
organicax: D365 warehouse mobile device apps Blog bot DAX Blogs 0 31.01.2017 23:14
organicax: Warehouse mobile device text colors some additional notes on setup Blog bot DAX Blogs 0 25.03.2016 12:11
emeadaxsupport: AX Performance - Analyzing key SQL Server configuration and database settings Blog bot DAX Blogs 0 28.09.2015 14:11
DynamicsAxSCM: Monitor and analyse current and future warehouse space utilization with Dynamics AX 2012 R2 Blog bot DAX Blogs 1 13.12.2012 01:01
Часовой пояс GMT +3, время: 15:42.
