Старый 08.04.2017, 19:11   #1
organicax: Quality association to a production order
Источник: https://organicax.com/2017/04/08/qua...duction-order/
If you are producing goods you might want to inspect them as a quality check. This could be manual. But if you need a document to trigger the recording of the action then you can use the quality order with a production order.
Now you could manually create a quality order but with a little setup in the quality association you can have the quality order triggered when the production is reported as finished.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Production control
organicax: Production Order – Operations vs Job Schedule Blog bot DAX Blogs 0 04.04.2017 02:15
organicax: WMS Mobile device menu – Start production order Blog bot DAX Blogs 0 01.09.2016 01:18
dynamicsaxtraining: Quality management Blog bot DAX Blogs 0 12.02.2011 00:11
Часовой пояс GMT +3, время: 19:56.
