Старый 07.12.2017, 04:27   #1
25,644 / 848 (80) +++++++
powerobjects: Portals: Changing the Date from the Default Format
Источник: https://www.powerobjects.com/2017/12...efault-format/
In Microsoft Dynamics 365, the date for Portals is in a USA format by default. In this blog we’ll show you a simple way to change the date to a UK format without using JavaScript.
1. Navigate to Portals in the dashboard
2. Click on Site Settings
3. Browse through the Site Setting records to check if you can find a record with “DateTime/DateFormat” in the Name field
If Record found:
4. Open the record and edit the Value field to the desired date format string
i.e. dd/MM/yyyy
5. Click Save
If no Record found:
4. Click +New to create a new recordUnder General tab enter:
Website: Your Portal Name
Value: The desired date format string i.e. dd/MM/yyyy
Description: Custom date format string
5. Click Save
6. Refresh your portal page with a date field to make sure your change has been applied
There you go, a simplistic approach to changing the default date format for portals in Dynamics 365! Keeping checking our blog for more helpful Dynamics 365 tips.
Happy Dynamics 365’ing!
crmtipoftheday: Tip #1027: Quick fix for the date format in portals Blog bot Dynamics CRM: Blogs 0 21.11.2017 08:12
Быстродействие метда TaxParameters::find Ace of Database DAX: Программирование 7 01.06.2017 11:46
goshoom: Preventing users from changing session date (AX 2012) Blog bot DAX Blogs 0 12.05.2014 19:11
CRM DE LA CREME! Some more useful javascripts for MS CRM Blog bot Dynamics CRM: Blogs 0 04.05.2010 11:05
Часовой пояс GMT +3, время: 02:20.
